Post UR Recipe for 13sec N/A 5.3 truck!
I'm new to the forum and it's pretty obvious that you guys are really well informed. I need to know if I can attain my goal with just a 5.3. Here are my requirements.
Must pass emissions.
Must be reliable (within reason of course, a tranny rebuild is already in the budget)
So far I have on order.
Full length Dynamaxx Headers (with cats) for an SSR
HPNtuner software
BTW my truck is an 04 Buick Rainer and weighs in @ 6,500lbs.
I get the feeling I'm gonna need a stroker, tell me it isn't so guys.
Sebastien
HPNtuner software
Sebastien
Check out the fastest truck list, particularly the N/A section. Are you sure that thing weighs 6500lbs? That thing is a pig, and I don't think you'll be able to do it with a NA 5.3. FI isn't so bad, what's your reason for keeping it NA. A radix kit is very dependable and you can get a damned warranty with it too!
Just out of curiosity, what gears does that thing have, and is it AWD/4WD???
Isn't the 6500 the GWV on that??
My GWV is like 6800 i think but is weighs 4600 with me in it (I'm 215), So I think that it weighs a lot less!!
If it weighed 6500lbs you would need around 585 HP and 690 ftlbs torque @ the flywheel!!!!!!!
Wheras I would need 414 and 488.
single digit dreamer
http://www.buick.com/rainier/features/specifications/
says 4600lbs
a stock 6.0 and a stall would get you real close and not cost much as all. if that dont do it then a few bolt on's would get you there for sure.
says 4600lbs
Adkoonerstrator
says 4600lbs
says 4600lbs
Stock 6.0 with maybe a small cam too. The stall in your truck should be the same as a trailblazer stall which has been giving decent results behind 6.0L engines.
Welcome to the site.
Performance Trucks Sponsor
I did a 6.0L LQ4 swap, LS6 cam, and tuning on a 4.8L yellow reg cab truck not too long ago, it's not much lighter than your buick.
I was very impressed with the results. He's running a 13.4 @ 98mph I believe.
So, I bet a 6.0L, 2600stall (i'm sure you drive it daily) and a cam will get you there with no problems.
good luck,
allen
good luck,
allen
well if you put a big **** cam in that thing you might be able to eak one out with probably like a 3000+ plus converter and some headwork with a bigger intake valve and such maybe mill em down a might. but i think you might just be able to eak one out with the ole 5.3 although like they say a 6.0 would work wonders on that thing
Cuz I AM a BADMOFO
On a prior 6.0 with a cam and a 200 wet shot of nitrous went 13.26 in a 62000 lb HD..
Cam and stage 2 ported heads w/ a 260 shot forged pistons on an otherwise STOCk bottom end 12.78
IMO:
I would say on yours, a 150 shot on a completely stock 6.0 with a cam and you will definately be there and would be safe on your motor..
If you ar ok with a little laughing gas..
If not, throttle body, air intake, headers, and a cam would get you close.. Cheapest would be the Nitrous.
IMO:
