Power steering pump squeeling. Is it going out?
My pump is squeeling and has a slow fluid leak. I filled it to the top and it still squeaks.
I was going to just replace the orings, but I was wondering if the whole thing is going out. What causes the squeeling?
I'm pretty sure it's the PS, because it squeels louder if I am parked and I turn the wheel just enough to put load on the PS pump.
It's not a horribly loud squeel, but it's enough to be annoying. Is there something I can lubricate, or should I just replace the whole thing?
Has anyone else's gone out? It has 175k miles on it.
![Bang Head](https://www.performancetrucks.net/forums/images/smilies/LS1Tech/gr_banghead.gif)
Thanks for any input.
Anyone who does this in the future, I recommend paying the extra $15 for the pump with the reservoir already attached. I swapped it all over, but it was a b**** because the bottom nut is very short and in a recessed area. It was also hard to get leverage on the nuts because of the awkward shape of the assembly.
Also, the pulley install tool was a worthless POS, so after cursing and throwing stuff, I fabbed up my own tool with a strap wrench, a bolt, a socket, and some washers. If that hadn't worked, I was going to bake it in the oven and then run outside and slide it on like some people do with the crank pulley.
Three hours later, the leaking and squeeling problems are solved, but I'm sore as hell.
![Grin](https://www.performancetrucks.net/forums/images/smilies/LS1Tech/gr_grin.gif)
dry_kill
11
08-28-2015 09:53 PM
lxcoupe
07-08-2015 05:49 AM
