Predator Guys in here!
Questions...
I need to know what the 4.8 guys have all the 1-2 shift points set at by
RPM...
MPH...
Trans pressure....
I'm pretty sure my 1-2 is going out. But I would like to compare info. It's like I'm hitting the rev limiter before the shift. I have it set at 5600 and 35mph (which is meaningless at WOT anyway)
Santa needs to bring me a tranny....and a Whipple owners manual
Sorry I haven't been around much, but we are in the middle of a shutdown at work....7 -12's and no days off so far.
RPM...
MPH...
Trans pressure....
Originally Posted by Fast4.8
Questions...
RPM...
MPH...
Trans pressure....
RPM...
MPH...
Trans pressure....
in a 5.3 mine was set on the dyno at
1-2 5750
2-3 5850
3-4 5850
stock cam fell off at that point. I need to re dyno since I changed my cam
p+e .50 %wot
spark 10.00 %
I got 26 rwhp with this combo
1-2 5750
2-3 5850
3-4 5850
p+e .50 %wot
spark 10.00 %
This is off the tranny subject but I need to know some stuff before I go and get a Predator. Octane, does it really matter? Do I HAVE to run it with Premium all the time or can I change the timing enough to run regular. I know the power won't be as great with the regular fuel but it is just too dang expensive to run premium all the time. Second, is the Predator worth the money to you guys? Is it really all that great or would you have done something else if you hadn't have bought the Predator. Any help you guys can give me would be great.
Do you still have your's with the cam and everything? My main concern is the fuel thing. Is it as user-friendly as they say? Are there still a lot of glitches in the programs and tunes like I have heard about?
1-2 5750
2-3 5850
3-4 5850
p+e .50 %wot
spark 10.00 %
1-2 5750
2-3 5850
3-4 5850
p+e .50 %wot
spark 10.00 %
Thanks, Jim
14 Second Truck Club
Preditor User Here, Does Anybody have any Info on fine tuning w/preditor. Such as how do you kwow if your running lean or rich, what should o2s readings should be and so on. Preditor works great but want more power if possible.
lxcoupe
07-21-2015 02:12 AM
