Is this Price Right for the Timing Chain?
#21
Originally Posted by Colby 04
it's a 5.3 chain, but they are the same chain on the LQ4 and the 5.3. The LQ9 chain is not any beefier, to my knowledge....I know there are LQ9 guys that have upgraded to the LS2 chain.
Thanks guys for all the suggestions!
jim
#22
Was doing a little bit of searching for the LS2 chain, but not too sure which one I need.
I found one from N-Motion and GM parts direct.
The one from GM parts direct say LS1, LS2, and LS6. For 45.00.
Colby04, which one do I need?
Which chain is the one in the photo posted in the previous post.
Jim
Jim
#24
Jim
Jim
I'm not sure of the part number, but it will fit any of those models....you need to call the dealership to get the part number to be sure it's the LS2 chain-the heavier one.
do a search on here, surely somebody has posted the part number.
#25
12556582 $16.86 crankshaft sprocket
12586482 $27.75 chain
12576407 $22.62 camshaft sprocket
search feature works wonders
https://www.performancetrucks.net/fo...2+timing+chain
#27
Well.....I should have done this before I ordered them, but when I went to pick them up today I noticed the chain wasn't all that big. But it does say heavy duty chain on the sealed package.
Anyways, for ***** and giggles I had the GM parts guy pull up the parts numbers for the chain and sprockets for a LQ9 6.0L in 05'. Well, it turns out that the part numbers listed above are the same ones for the LQ9 6.0 block.
Anyways, I thought you guys said that I had a regular chain in my engine?
Now I will have to send these parts back and loose 20% for restock fee.
Anyone else have knowledge of the chains and gears in the LQ9 6.0 and the LS2 6.0???
Jim
