Problem with Nelson fan harness please help
Old 02-10-2006, 07:30 PM
I have the same problem. I had to put in a toggle switch in and run the fans like that. It is a pain in the *** because sometimes I either forget to turn them on or turn them off. Damn I need to get that fixed.
Old 02-10-2006, 08:00 PM
98TAauto's Avatar
01, i feel ya man... it erks me that i spent the money for the dang harness and it only works with the AC, heat, or defrost on
its cold out now so the truck hardly hits 210 unless im in mc'ds drive thru for 15mins.. but summer heat is gonna suk so i have to get it fixed
Old 02-10-2006, 10:33 PM
Colby 04's Avatar
Has anybody questioned Allen about this?
Old 02-11-2006, 06:33 AM
Dark Halo's Avatar
I have emailed him twice I am just waiting on a response. If I do not get anything by the weekend I will call him and find out or have him send me a new harness.
Old 02-11-2006, 06:37 AM
bud8fan's Avatar
i also had this same problem and i did not have the pin in the proper place...#42 pin....after pushing and pulling and bending the pin i took it to allen and he fixed it in 3 minutes....it works...just have to get it in the right place....
Old 02-11-2006, 09:47 AM
Colby 04's Avatar
I emailed him when I installed mine. It took something like a week to get a response, by that time I had already figured everything out. Although, I emailed him on a Sunday one time and he responded that evening...
Old 02-11-2006, 10:55 AM
SnakeOiler's Avatar
You guys with the problems: If your manual switch is working properly, then there is nothing wrong with the harness - the problem is in the terminal connector for the PCM.
Either it is not in the Blue pin 42 location or it is not seated properly. It is a very difficult thing to do (getting it seated properly). Check it out.
Old 02-11-2006, 11:54 AM
PT's Slowest Truck
budhayes3's Avatar
If you manually ground the blue wire that goes to pin 42 and the fans come on low, then you know that everything from there on back is OK, and either the pin isn't seated in the PCM, it's in the wrong spot, or the PCM isn't tuned to ground pin 42...or the PCM could be faulty not allowing pin 42 to ground.
Old 02-11-2006, 12:23 PM
11 Second Truck Club
bluecajun5.3's Avatar
thank you snake and bud. i will do when my retune get's here monday.
Old 02-11-2006, 06:56 PM
Dark Halo's Avatar
I dont understand unless nelson forgot to tune the PCM for the fans. I had told him about it and I still have not heard from him about it. I double checked everything today and it is all installed right.
97gmc
22
09-08-2015 10:56 PM
jleews6
09-08-2015 10:17 AM
muncie21
09-07-2015 09:55 PM
mayko
09-07-2015 12:24 PM
Alvin@PCMofNC
09-03-2015 06:38 AM
Quick Reply: Problem with Nelson fan harness please help
