problems after heads and cam swap
Old 03-17-2009, 12:11 AM
formerly charlyroxs411 (changed 11/19/2012)
LS3powered's Avatar
Oh, and the cyl that are missfiring are 3,5,7
Old 03-17-2009, 12:31 AM
PT's Slowest Truck
budhayes3's Avatar
What does the O2 sensor activity look like, could be a bad bank 1 O2 sensor, or maybe injector ground on that side or you could have a plugged cat on that bank. Seems like all of bank1 (except for cyl 1) is misfiring...you could try swapping the O2 sensors side to side and seeing if the misfires follow...
Old 03-17-2009, 01:32 AM
11 Second Hall Moniter
AKlowriderZ71's Avatar
You need to check exhaust backpressure on both banks, before the cats. It sounds like a plugged cat.
Old 03-17-2009, 01:35 AM
nd the diagnostic said the timmking was off
Is that supposed to be Timing?
wouldnt that explain a lot?
Old 03-17-2009, 06:58 AM
white lightning SS's Avatar
I feel pretty confident you have a plugged bank one cat. Check backpressure or pull the Y-pipe off and inspect.
OHsixLS3
12-27-2016 09:30 AM
GrooveCityZ71
08-31-2015 12:05 PM
steves86ta
07-28-2015 10:21 AM
4B11T
07-13-2015 03:48 PM
Aboss
07-09-2015 10:28 AM
Quick Reply: problems after heads and cam swap
