problems with the flexalite vsc
I have the FAL fans on my truck and they work great, but the weak link is the VSC. When the VSC work, it works well, but it isn't built to handle the high voltage and overheats. I'm on my second one now, the first one overheated and the lugs melted and fell off the VSC.
I'm on my second VCS now and I have to check it periodically after heavy uses of the efans. I was wondering if it were possible to use wire in a relay between the vsc and the fans to alleviate this problem.
Originally Posted by 02denali
yes the nelson harness will work for your app. but the temps will have to be set in the pcm for it to work.
2002_Z28_Six_Speed
10-04-2015 01:34 PM
