Procharger guys, MAF lb/min?
Just curious, whats your max MAF reading? Mine's 406 lb/min at 5800 rpm and 8psi. I know this seems low, but I am at 5000 ft elevation, and we have about 20% less air up here. Any guesses what 3 more psi will take it to? Got the Reichard Racing 3.6 pulley coming in the mail,hope it doesn't slip!
Adkoonerstrator
Re: Procharger guys, MAF lb/min?
Yikes....I hope you mean 40.6 lb/min or you'd be giving top fuelers a run for there money.
I would say you'll see around 44 lb/min if you up the boost 3 more psi.
My max maf reading is 32 lb/min...Oh wait, I don't have a procharger on the truck.
your going to see more than another 3psi with that pulley
Be carfull with it !! let me know how many psi it will run and if your slipping your belts be interesting
jim
jim
single digit dreamer
My Radix kit would pull a MAX of about 8.5 psi and the MAF was showing a max of just over 57 lbs/min.
that pully should do you good
My MAF maxs out around 5,400 or 5,700, it depends on my belt. As soon as I figure out my new intercooler and pulley problems I will post again. That is if I get it fixed, it has been about 3 weeks, 3 pulleys, and 5 belts.
Procharger says to go back to the 4.5in 8lb. pulley and I should see 2-4lb of boost gain and no more belt problems. I just learned this Friday. I will see how it goes.
