procharger intake relocation pics.
Home Depot to the rescue! This is where ATI should position the filter. I would try to seal the filter from the engine compartment but even like this it's better than what you had before!
thanks guys!! i have a feeling the one piece 3inch manderal stainless coated is gonna look great! right now i havent sealed the filter off because my wheel wells are off because i recently had to pull the motor off the mounts to get to a header bolt that broke off in the head and if youve ever done it through the wheel wells.....you know its a million times easier to get to the mounts right away. when i put the wheel wells back on im pulling off the stock airbox tray and sealing off the filter. im surprised the admins havent banned this name i registered last night. its good to be able to get and give feed back to you guys once again even if it doesnt last!
i thought about that option and i still might try that but this way is so easy and simple it literally took 10 mins to think of and less than 30 bucks to put together i think anyone with an ATi should at least try it. if i try the other route by the battery directly in front of the blower, i might even be able to get away with not having to relocate the battery if i can relocate the bypass valve...im getting really frustrated with ATAP! i cant connect. im almost positive my IATs are down since i already logged with it on and im seeing the same amount of boost.. just havent done a log with it off since...the trucks been down a long time.
