Professional Products 85mm or 96mm Inlet Intake
I can get the professional products intakes pretty damn cheep(cheeper than an ls6 intake) and i was just wondering which intake i should go with..im leaning towards the 85mm inlet with the 85mm throttle body which i can get tb under 200 bucks..or should i got with the 96mm inlet intake and get a 90mm throttle body..all i may do in the future is put some flat top pistons and ls6 heads on it and maybe bigger cam
The jury is still out on them from what I have read on tech. I honestly dont see you needing a 90mm if you are only going to put a set of better heads and MAYBE a bigger cam. They sure are purty though
wow those look pretty nice. ill have to check them out. keep us posted on any links you find. ill also look around and if i find any good dyno;s or anythign ill post it up for you.
