Programming 4:10 gears
Re: Programming 4:10 gears
actually fellas mine is pewter and I didn't get any of the graphics, I already took the exhaust tips off and put turndowns, but like ranwalk said, I do have the head rests, and I've also got the painted interior. Also when I put my truck in tow/haul mode, and get on it my truck hits the rev. limiter before it shifts out of gear, do I need to adjust my limiter or should I take my tranny in??
What does the real time data say in your predator.
I believe it is right under Engine rpm.
start truck plug in programmer, select diagnostics, select automatic, select real time data. The readout doesn't all fit on one screen so you'll have to scroll down.
eng load
ect
stftb1
ltftb1
stftb2
ltftb2
map
eng speed
veh speed
spark
iat
maf
ho2s 1
ho2s 1
ho2s 2
ho2s 2
KR
eng load
ect
stftb1
ltftb1
stftb2
ltftb2
map
eng speed
veh speed
spark
iat
maf
ho2s 1
ho2s 1
ho2s 2
ho2s 2
KR
that readout actually matches my speedo, you don't scroll down to see vehicle speed
I'm confused, unless the predator is f*cked up your speedo should be accurate.
The only way you know your speedo is off is by running next to your friend?
Do you Know anyone in Law enforcement that could get you on Radar?
Not in OKC, but when I drive on base there usually some of those radar machines sitting beside the road(the ones that tell how fast you are going, and if it's about 5 over the speed limit it starts flashing)and the other day I drove by it about 4 times after reprogramming my truck everytime, and everytime my speedo said 30, and that machine said 25...
