Are pullies worth the install ???
Well just like the title says are they worth it?
I wanted to get your opinoins on what you guys thought. Im doing a cam swap and LS1 fans and thought of maybe getting a underdrive pullie set along with it.
Then I thought about the e fans and maybe I might have issuses with drawing to much power from the battery and the alt. not being up to par. I also know they have a overdrive pullie for the alt. but I dont know the postives and negatives to doing the pullie change.
Basically let me know what your guys personnal experience using combination of underdrive/underdrive or underdrive/overdrive or even just the underdrive pullie and leave the alt. pullie alone.
Thanks in advance
Thanks in advance
if oyu are doing a cam swap. you might as well go ahead and do a pulley at the same time. you lready have the stock pulley off.
it will be fine with the pullies and elec fans.
and they are very much worth the money.
LCHEE
10-24-2020 04:10 PM
zblee
08-03-2015 03:45 AM
sauldgold
07-23-2015 02:15 PM
