Pulling the motor!!! Need some assistance please.
Old 04-21-2006, 01:05 PM
TURBHOE's Avatar
my fuel line and cross over i just hung up on my hood. did you put your hood in the "service position"? it helps to not have to take it off.
Old 04-21-2006, 01:06 PM
01Blackerado's Avatar
never knew there was a "service position" What do I need to do to do that?
Old 04-21-2006, 01:07 PM
Originally Posted by Zick
Don't see why not, you should be able to flex it out of the way. If not, go to sears and get the fuel tool for like $10.
Nice!!! Thanks for the info
Old 04-21-2006, 01:09 PM
white1's Avatar
On your hood hinges, unbolt teh front bolt (I think its the front one) then stand teh hood straight up and put the bolt in the other hole. On my intake, I just used a trox screwdriver and removed teh fuel rail. Just be sure you dont loose teh O ring, its a bitch when you go to crank the engine and spray everything with gas then have to find somewhere to get an O ring late at night. So I hear at least
Old 04-21-2006, 01:40 PM
Thanks!!! I'll ive it a try when I get off work today!!
Old 04-21-2006, 05:13 PM
TURBHOE's Avatar
yeah unbolt the hood from the hing itself, then lift the hood striaght up and put the hing up to the back hole and run the bolt through and put the nut on. you don't have to tighten it just finger tight.
Old 04-21-2006, 10:45 PM
Colby 04's Avatar
That tip should go HERE
Old 04-22-2006, 02:58 AM
High on diesel fumes
thunder550's Avatar
Tip has been added
Old 04-22-2006, 05:18 PM
Colby 04's Avatar
Originally Posted by thunder550
Tip has been added
thanks for the pic too
Old 04-25-2006, 12:51 PM
thunder550's Avatar
Hey Blackerado, did you end up getting the engine and tranny out?
Quick Reply: Pulling the motor!!! Need some assistance please.
