Pushrods. Again... Unsure...
![Arrow](https://www.performancetrucks.net/forums/images/icons/icon2.gif)
I have the truck in sig. I'm installing a set of tsp 2.5 5.3 862 heads milled .030 with stock mls gaskets, new ls7 lifters, and a tsp 220/220 .581 112 cam.
I've been reading for the past hour several posts on pushrods lengths etc...
I have no time for down time to order pushrods after using a checker. I have a few sets of comp hardened pushrods. 7.425's, 7.4's, and 7.375's. Should I order 7.350's and 7.325's just to be safe? That should be the last thing I need to get besides dexcool.
Also if my lifter trays look good will they be ok with the ls7 lifters?
Thanks a bunch,
Steve
Thanks a bunch,
Steve
7.375s. Trays will be fine unless you have over 150k miles then id replace them. I always seem to have least amount of valve train noise with 1 1/4 to 1 3/4 turn on the rocker bolt from 0 pre load (just snugged up with your fingers)
Every pushrod is the same out of the factory, and the pushrod gos nearly straight down from the base of the head/block, mill.030 get.030 shorter pushrods this will get you within .005 every time (plenty safe) the cam base circle 'should' be known by the company that sells it to you but they never do, the comp xer cams are all prettyclose when I've checked them, I've always needed a 7.4. Really big cams might need a longer one.
... mill.030 get.030 shorter pushrods this will get you within .005 every time (plenty safe) the cam base circle 'should' be known by the company that sells it to you but they never do, the comp xer cams are all prettyclose when I've checked them, I've always needed a 7.4. Really big cams might need a longer one.
FormerVendor
