Question about my LT1 fans, how much will they run in the summer?
Old 03-06-2003, 03:25 PM
Default Question about my LT1 fans, how much will they run in the summer?
We've had a mild winter in Northern Cali and Spring has already sprung here. I've noticed that the fans are already coming on some if I sit in traffic or in a fast food drive through for a while. Temp has been 68-70* last two days, they've come on a couple of times. When it's 90+ this summer, how much should I expect them to run? I generally don't use the A/C unless it's 95+, will the fans be on constantly at lower speeds or just when I sit for a while?
Thanks <img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" />
Jim
Old 03-06-2003, 03:47 PM
BigKID's Avatar
Default Re: Question about my LT1 fans, how much will they run in the summer?
Mine usually stay on in the summer in south MS. I have my thermo set at 170 though and my truck runs about 180-185.
Old 03-07-2003, 12:11 AM
CashDudeHomie's Avatar
Hey dude lay off the fast food! <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" /> Actually I kept having trouble with the thermostats and relays and crap, so I wired my fans to where they always run when the truck is running. It has been like that for probably 8 months or so and so far no problems. I think the fans are built to last a very long time so you don't have anything to worry about. Also my fans came off a wrecked 99 TA so they had plenty of hours on them before I got them. Dude how did you mount your fans? I want to get rid of the radiator zip ties before they bust something and need suggestions. Do you have any pics of your brackets? Thanks dude.
Old 03-07-2003, 12:20 AM
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Dude how did you mount your fans? </font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">I used metal brackets! I got some 1" wide by about an 1/8" thick metal scrap from work and bent them. I used the hole that the top shroud screws went into, I had to make a little off set in the brackets so they would line up properly. I just put two self taper screws in the fans frame to hold the bracket to the frame. On the bottom, I did the same thing but the bracket didn't need an off set. I used self taper screws again, one in the lower radiator support and one in the fans frame. It's prettyy solid, does move and the screws stay tight. I may switch the wiring on the fans to run one when the trucks on and have the other one on the thermostat.
Jim
Old 03-07-2003, 12:24 AM
Thanks man. I am going to try the brackets out soon. I bought some just like you described but I wasn't sure if they would break if I tried to bend them. Thanks for the reply man!! <img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" /> Oh yeah congrats on getting the converter installed. It will be cool to see how many tenths it gives you when you hit the track.
Old 03-07-2003, 12:59 AM
graygmc's Avatar
yea they will probably stay on most of the time in the summer. thats what mine did anyways.
stealthperf
34
02-14-2016 11:35 AM
thunder550
10-08-2015 04:53 PM
Bluchevypick
08-18-2015 09:11 AM
hartinclay
08-02-2015 06:44 PM
Quick Reply: Question about my LT1 fans, how much will they run in the summer?
