Question on ARP Rod and Main Bolts/Studs
So I will be upgrading to ARP bolts on the rods and studs on the mains. Question is, can I just remove the bolts and replace with ARP and torque to spec or is there any special thing I need to do? I will not be removing the crank or rods or anything. Just changing the Bolts. I will be using the correct ARP Ultra Torque fastener assembly lube on the bolts as well.
Perfect guys, appreciate the fast responses. I will have it done right and will hone the mains and rods. I am trying to get all my ducks in a row before I add boost.
The stock spec of 15 ft lbs and then 75 degrees of twist on the stock bolts versus using ARP's doesn't distort anything. I tried it on a set of LS rods at my friends engine shop on his machine and they did not change. Lots of LS rods are just out of round... stock bolts or otherwise. Mains should be checked and may need align boring... my last block though as example did not.
