Question bout ls1 heads and intake
11 Second Club
before you jump into this lemme give you some links...it's not just a bolt on affair...well it is but you don't just take your truck intake off and bolt your ls1 intake and be ready to go...its quite a bit more involved...you'll need new fuel rails and injectors, an idler pulley relocator, an ls1 water pump, not to mention the fact that the truck intake actually flows better than the ls1 intake...but the ls1 intake is much better looking. Do some searching before you jump into this...
https://www.performancetrucks.net/fo...d.php?t=357424
https://www.performancetrucks.net/fo...=weiand+intake
https://www.performancetrucks.net/fo...ght=ls1+intake
GrooveCityZ71
08-31-2015 12:05 PM
