Question on the SDPC HT-1 Cam
Hopefully one of the Scoggin Dickey guys will see this...running this in my 4.8 and its a great cam. My question is about the ramp rates of this cam and if 1.8 rockers would work well with it or not?
edit: Cam Specs: 214/218 .559/.563 111 LSA 109 ICL -6* Overlap
FormerVendor
From the looks of it I do believe that cam is on the XE lobes which aren't super aggressive as far as ramp rates go. However if you are still running those LS6 springs that are in your sig I would advise against running the 1.8 rockers on those springs. You'll be near .600 lift with the 1.8s and I think you'd be pushing your luck a bit.
bbowerman
07-26-2015 10:57 PM
