Questions about adding factory e-fans to my 04 silverado
#21
Pin 33 (hi) and 42 (lo) are both "switched to ground" by the PCM to activate. Just make sure that the PCM pins are hooked to the "ground" leg of the relay circuits, not 12V. Hope this helps.
#26
I'm pretty sure you have to use the "aux fans" and not the "2 fans" setting for the older pcm. I should be getting my nelson harness monday and messing around with efans the weekend after.
#27
From what I remember when I did my 05 efans, the radiators looked the same except for the cores....but that was a few years ago. You won't have to drill and tap for the fans, they slide right in. You'll just need 2 more bolts for the upper fan mounts...if you want to be really **** you can get them from the dealer so it looks totally stock You'll have to trim the 2 rubber flaps on both sides of the radiator with a razor blade or even scissors since the 34" rad is wider (no biggie, you don't even see them), and get or make a harness. I have the Nelson harness and it's been flawless for me for about 4 years-ish now. Then tune the PCM to turn them on and off at your desired temps.
My 05 fans....(I used aftermarket bolts to secure mine...I'm kinda **** myself so it bothers me a bit, I may swap them out some day...)
5.3lSilverado
25
08-29-2016 12:48 AM
