Questions about crankshaft length
Old 02-24-2008, 11:58 PM
Custm2500's Rude Friend
1FastBrick's Avatar
Originally Posted by shakinlm7
I'm not saying that that any of the info is wrong because I don't have a clue but I read the whole post and the chamber size they have listed for the 708 heads doesn't match up with what I have seen on other posts.
Old 02-25-2008, 11:44 AM
Dark Halo's Avatar
Originally Posted by TurboGibbs
Good luck! Your projected times sound doable with slicks. Remember, it is hard to get a manual to launch, even with slicks. You usually have to do a 5k or more dump to get one that is even geared properly to get it leave like an auto with a 3000 stall. With 5000 rpm + dumps you run into severe axle wrap issues if you don't have any traction divices which will break springs, housings, spider gears, axles, ujoints and driveshafts. Oh, and transmissions, pressure plates, rip the center out of clutch discs etc. I have been drag racing manuals for years and have broken all those items at least once and then some. A manual with 300 rwhp will break more drivtrain parts than an automatic with 600 rwhp.
I will be putting a t56 in my 92 what do you recommend in order to make some good times at the track? I will be getting caltracs as they have done wonders on my 02.
blownss27
08-14-2020 08:27 AM
outlawz2004
09-19-2015 08:12 PM
Alco
09-04-2015 04:08 PM
Tigger Welder
09-02-2015 08:17 AM
USMCvet0311
08-01-2015 07:45 AM
Quick Reply: Questions about crankshaft length
