Quick 6.0l Crankshaft ?
Old 03-11-2007, 03:36 PM
2002C5COUPE's Avatar
Default Quick 6.0l Crankshaft ?
I found a crank on ebay and it has this casting # and gm part #
Is this the casting # i should be looking for to complete my swap? :12552216
this is supposedly the gm part # 12559354
i looked up this part# and i think it's an LS1 crank, but I've also read that the #216 casting # is the one i should be looking for because it's the 01+, short flange style
Old 03-11-2007, 04:05 PM
FormerVendor
Derek @ EDO's Avatar
12559354--ls1
12559357--lm7
12561302--lq4
Old 03-11-2007, 04:10 PM
Originally Posted by DLH2006
12559354--ls1
12559357--lm7
12561302--lq4
thanks!
but what about the casting #? do LS1 cranks have the same # as some LQ4's
which casting # should i be hunting for?
does anyone ever use LS1 cranks in 6.0l?
sorry for all the ?s ive searched all over and haven't found any answers
Old 03-11-2007, 04:39 PM
Tootall's Avatar
from what I've heard, read, looked at the junk yards, all ls1 5.7s and truck 5.3 6.0 are the same.
Same size bearings, unless they've been turned.
Same stroke, all internally ballanced.
You cannot use a 4.8 pulley on the above. Again just from what I've read, and from talking to the junk yard dealers.
PM mater or chevracer83 and they can tell you
Old 03-11-2007, 04:43 PM
negativeswitches's Avatar
i've heard the ls1 cranks are hollow
:shrugs: that was on tech try there
i saw where the difference between the LS1's and the 6.0's is that the LS1's are hollow and have extra oiling passages somewhere.
has anyone here actually used an LS1 crank in their 6.0 swap?
this is the 1st i've seen anywhere about having to use a different crank pulley.
Old 03-11-2007, 09:57 PM
bump ttt
Old 03-11-2007, 11:53 PM
Tootall's Avatar
I never did check the difference in size on the pulleys, I'll check from my old one and see if there's a difference.
There's a TON of people that have done 6.0 swaps on ls1tech, post up over there and ask, you might have a faster response.
calsdad
06-14-2023 11:07 PM
Wrecker 426
10-07-2015 12:11 PM
old motorhead
09-29-2015 08:22 PM
sTNT971
09-26-2015 04:22 PM
Quick Reply: Quick 6.0l Crankshaft ?
