quick 6.0l question..
Old 07-06-2006, 11:06 PM
5 year bitches!
Quik's Avatar
yep high CR is sweet
Old 07-06-2006, 11:19 PM
One_Slow4.8's Avatar
do you think i would be ok. trying to pass emissions with a high cr motor?? and a radical cam?
Old 07-06-2006, 11:31 PM
It all depends on your custom tuner you pick to get a high compression motor with a radical cam in it to pass emission testing.
Nelson can hook you up in that department when you are ready. Just go over the cam choice with Nelson before making a final cam decision.
Jim
Old 07-07-2006, 10:05 PM
ok.. i have a 4.8 now (And i dont plan on changing the headers or cats.) if i bought a corsa, would it stilll work with the 6.0l when i do the swap? becasue it is in a different catagory on tbyrne i am almost 99% sure it does
Old 07-07-2006, 10:52 PM
5 year bitches!
Quik's Avatar
yes but you would be choking it some. 6.0s use a differetn exhaust setup. but im using my catback from my 5.3 setup but i made my own ORY pipe mated to my Fbody headers
if you do 6.0 you will need to use your 4.8 manifolds to get your exhaust to work
Old 07-08-2006, 12:14 PM
High on diesel fumes
thunder550's Avatar
I thought all the manifolds were the same? And the exhaust too - I reused my Corsa.....
Old 07-08-2006, 10:15 PM
so is that a resuse or is ait a dump it 4 something else
calsdad
06-14-2023 11:07 PM
Wrecker 426
10-07-2015 12:11 PM
old motorhead
09-29-2015 08:22 PM
2004gibbstruck
09-07-2015 06:05 PM
Quick Reply: quick 6.0l question..
