Quick cam question
Do y'all think I'm gonna have clearance issues running a cam with this much lift on stock heads? Here is a link to the cam specs.
54-455-11 - LSR
54-455-11 - LSR
FormerVendor
Pretty good cam. These newer lobes Comp is using with the LSR cams are making good power and torque, those look to be the LSL lobes.
You could have 1" of lift with the right valve events. Lift does not dictate piston to valve clearance, duration and LSA do. In short yes you will have no issues with piston to valve clearance.
bbowerman
07-26-2015 10:57 PM
