quick injector/coil pack question
Originally Posted by jakebdb56
the truck coils will not mount to the ls1 coil bracket. had this problem recently. also the truck coils will not wire into the ls1 coil harness. if you wanna use your truck coils/brackets/harness on your ls1 itll work as long as you use the whole harness and bracket and all the coils.
injector size for the ls1 is the same too I think. i'll check my book when I get home
also ive heard the ls1's use 29# injectors and have heard alot of them use the truck coils on the cars...any explinations?
Originally Posted by Tahoe6.0
I understand that E85 / flex fuel 5.3's have 33lb injectors, thats what my tuner said! So we used the 5.3's on my 6.0 converson.
im using the ls1 motor with the truck intake and coils. also using my trucks injectors over the ls1 injectors only because mine are lower milage so no worries there
5 year bitches!
thanks quick...so i plan to use the 5.3(lowest miles) injectors with the truck coils on the truck intake...thanks for the answers guys
also putting 100 shot of spray through the combo with the stock 98 ls1 cam which is the largest stock cam over the years. the injectors should handle that no prob right?
5 year bitches!
