quick injector/coil pack question
Old 11-30-2006, 05:04 PM
04BlackSilverado's Avatar
I have a set of 32# 8.1 injectors for sale, under 1000 miles on them. PM me if your interested.
Old 11-30-2006, 05:56 PM
Tahoe6.0's Avatar
I understand that E85 / flex fuel 5.3's have 33lb injectors, thats what my tuner said! So we used the 5.3's on my 6.0 converson.
Old 11-30-2006, 06:12 PM
TXsilverado's Avatar
Originally Posted by jakebdb56
the truck coils will not mount to the ls1 coil bracket. had this problem recently. also the truck coils will not wire into the ls1 coil harness. if you wanna use your truck coils/brackets/harness on your ls1 itll work as long as you use the whole harness and bracket and all the coils.
injector size for the ls1 is the same too I think. i'll check my book when I get home
im using the ls1 motor with the truck intake and coils. also using my trucks injectors over the ls1 injectors only because mine are lower milage so no worries there
Old 11-30-2006, 06:16 PM
also ive heard the ls1's use 29# injectors and have heard alot of them use the truck coils on the cars...any explinations?
Old 11-30-2006, 06:24 PM
Yes, but the plain 4.8/5.3/6.0 injectors are around 26#'s
Not sure what the LS1's are, but if you cam the 5.7 you may be close on the duty cycle with the truck injectors. The 8.1's are a direct swap over the LS1's, worth it IMO.
Old 11-30-2006, 06:32 PM
5 year bitches!
Quik's Avatar
for my old setup i ran 6.0 coils on LS1 brackets, as for truck coils see i dont beleive that since i used truck coils on the pinks car which used a car harness
Old 11-30-2006, 06:33 PM
5 year bitches!
Quik's Avatar
98,01 and 02 forthe LS1 are 28#s
99,00 are 26#s
Old 11-30-2006, 06:38 PM
thanks quick...so i plan to use the 5.3(lowest miles) injectors with the truck coils on the truck intake...thanks for the answers guys
also putting 100 shot of spray through the combo with the stock 98 ls1 cam which is the largest stock cam over the years. the injectors should handle that no prob right?
Old 11-30-2006, 06:42 PM
Tin Foil Hat Wearin' Fool
1slow01Z71's Avatar
Why the hell are you going to do a motor swap and not throw a good cam in there?
Old 11-30-2006, 06:46 PM
5 year bitches!
Quik's Avatar
actually the vette cam of thsoe years is the largest Nonls6 cam. and if you compared it itsnothing more then a 6.0 truck cam
Quick Reply: quick injector/coil pack question
