quick injector/coil pack question
Old 11-30-2006 | 07:48 PM
  #21
TXsilverado's Avatar
it will already have the 918's it it so the cam swap will be gravy when i come up with the dough. i spent my cam money on a new cold fusion nitros kit. i graduate in may and will hopefully have a real job by the end of june so then ill have some extra money to really play with
Old 11-30-2006 | 07:54 PM
  #22
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
Used cam on tech is 200 bucks, you are telling my you cant squeeze that out between now and when you do the swap? I would hold off on the swap till you can get cam since its SOOO easy to do out of the truck.
Old 11-30-2006 | 07:58 PM
  #23
Quik's Avatar
5 year bitches!
also depending on cam size the 918s might not work
i got a cam forsale but it might be too large for your taste
Old 11-30-2006 | 08:11 PM
  #24
im looking for a 224/224 .581 .581 112 or a 226/226 .581 .581 12 so the 918's will work with either cam...most likely going for the 224 because of my small torque converter.
also trying to avoid any disagreements with the old man. lumpy motors are more likely to get caught with. im still going to college under his money so id rather not **** him off too much. especially when its only about 5 months till graduation.
Old 11-30-2006 | 09:37 PM
  #25
Talking
im using the ls1 motor with the truck intake and coils. also using my trucks injectors over the ls1 injectors only because mine are lower milage so no worries there
Quit "nit picking" over some damn coils!!!!! Either ones will work fine!!!
Now hurry up and get finished with your swap so you can give me a hand with my HP/TQ Multiplier thinga majiggy!!
Jim
Old 11-30-2006 | 11:38 PM
  #26
1slow01Z71's Avatar
Jim
You are one to be talking about being nit picky
Old 12-01-2006 | 12:13 AM
  #27
Cool
Oh your right about that! I was just pickin at him for picking at me in my oil pump thread.
I know I'm pretty picky, but I just want my set-up to work out for me and be reliable. You know what I'm talking about I'm sure. The difference between your truck and my truck is mines a DD truck and yours is an occasional driver (if your lucky)
Jim
Old 12-01-2006 | 04:29 AM
  #28
jakebdb56's Avatar
Originally Posted by Quik
for my old setup i ran 6.0 coils on LS1 brackets, as for truck coils see i dont beleive that since i used truck coils on the pinks car which used a car harness
it can be a whole car harness, but the actual coil harness has to be the truck coil harness in order to use truck coils. trust me, I learned the hard way that the ls1 coils will not work on the truck harness, and vice versa.
Old 12-01-2006 | 06:39 AM
  #29
Quik's Avatar
5 year bitches!
they were truck coils with the truck plug on a car harness. im telling from my experience how thigns work. now maybe since yours is newer its different but i will say that it can be done from my experience
blownss27
08-14-2020 09:27 AM
03sierraslt
09-06-2015 07:53 PM
Cowboy Tom
09-05-2015 05:29 PM
Alco
09-04-2015 05:08 PM
Three6GMC
08-28-2015 08:56 AM
