radiator and 05 efan upgrade
Old 02-18-2008, 09:16 PM
getchusum99's Avatar
Default radiator and 05 efan upgrade
what all do u have to do to put the 05 and up bigger radiator and e-fans to go with it. ive been wanting to do this for a while and i think its time. ill just sell my ls1 fans afterwards.thanks,denny
Old 02-18-2008, 09:18 PM
truckmann's Avatar
Radiator is a direct drop in. For the fans it depends on how you want to wire them. The easy thing to do would be to use the same harness you are using for the ls1 fans.
Old 02-18-2008, 10:45 PM
mbell's Avatar
there's no moding needed to fit the bigger radiator ?? it will just drop in
Old 02-18-2008, 10:53 PM
xlcooplx's Avatar
yep..
Old 02-18-2008, 11:13 PM
04bluesilverado's Avatar
exactly
Old 02-19-2008, 11:05 AM
PT's Slowest Truck
budhayes3's Avatar
Radiator drops right in, you just have to trim the rubber flaps on both sides of it attached to the radiator support.
Old 02-21-2008, 09:34 PM
does anyone have the gm part number for the upgraded radiator?"
Old 02-22-2008, 11:05 PM
SyTy Speed Shop
HotRodV6's Avatar
I got the bigger rad and efans from a 2007 NBS truck, and the rad and fans dropped right in, and i didnt even trim the rubber flaps, i also completely flushed out the old dexcool and put in some prestone coolant. I used a harness from Nelson Performance and it works great, the *** dyno says there was alittle power there, ive seen people say something like 15 horses, but i dont think it was that much.
Old 02-24-2008, 09:23 PM
i already have ls1 fans i just wanted to get the bigger radiator for better cooling , i definately noticed a difference when i took the ol clutch fan off. on what year models did the bigger radiators start coming out?
Old 02-24-2008, 09:30 PM
truckmann's Avatar
Here is one. http://cgi.ebay.com/ebaymotors/99-SI...spagenameZWDVW
I got mine from radiator.com they price matched ebay and have a warehouse local to me so I got it delivered to my door the same day I ordered.
Porscharu914
14
01-20-2016 10:45 AM
carid
10-28-2015 08:24 AM
TrickTurbo
09-23-2015 08:41 PM
Noah Burns
09-13-2015 09:28 AM
sTNT971
09-11-2015 02:38 AM
Quick Reply: radiator and 05 efan upgrade
