Radix and Belt Slip?
Check this out, very nice:
LS1 8 Rib Supercharger Drive
![](http://www.atiperformanceproducts.com/links/pr/8-rib-pulley.jpg)
http://www.atiperformanceproducts.co.../pr/103002.htm
another gem:
Eliminate Damper Shift with the ATI Crank Pin Drill Fixture Kit for LS1
http://www.atiperformanceproducts.co...s/pr/30402.htm
![](http://www.atiperformanceproducts.com/images/prcpass.jpg)
blownerator
This is pretty nice!!
Magnacharger has nowhere near the slippage that a ProCharger has.The 8 rib belts would probably rob more power than the 6 rib pullies lose to slippage.The ATI balancer would be nice if you spin the motor to 7000 rpm[not likely with a Radix].Let the ProCharger guys worry about belt slippage,they have to rev their superchargers to excessive speeds,the Radix guys don't.
Hopefully someone will give this a try and report back.....I'm also interested what BlownChevy has to say on this.
