RADIX Boost/Idle Questions
ttt.....
Still need to know what the boost difference is between the 3.70" pulley and the 3.4" pulley on the 5.3l engine. What's 3/10's of an inch worth? (in boost, funny guy) Is it worth swapping the pulleys? Since the tune is set up for the 3.4" will it throw the PCM off?
Got the tune in, took awhile for it to smooth the idle out, but it did. I drove around for a few minuted to feel it out, turning the a/c on and off, putting it in park and so on. After a few minutes I decided it was time to try it out. Found an empty stretch of road and eased into it. Pulled real nice. Then I turned around and stomped it from a dead stop. The 24's made a quick chirp and I was off (Interesting because I did not have the traction control off). The 3.70" pulley maxed out at 6 psi at WOT. I wil be swapping it to the 3.4" shortly. After this question:
Will I need a pulley puller to get the pulley off the snout of the Radix or will it slide off with enough elbow grease, AND do I need to add loctite when I put the new pulley on?
blownerator
The pulley may just come off....It depends, try to pull it off first and go from there....Just DO NOT USE ANY AIR TOOLS ON THE PULLEY NUT. Glad you got everything worked out, try it with the T/C off....It will not go into PE if it thinks the wheels are spinning
P.s. what is PE? (It will not go into PE if it thinks the wheels are spinning )
