Radix heat exchanger
Old 02-05-2005 | 09:56 PM
David Cairns's Avatar
Just add some ducting and electric fans, and you are all done
Old 02-05-2005 | 10:35 PM
moregrip's Avatar
what a rush!
did you notice lower IAT's with the ducting?
Old 02-05-2005 | 10:46 PM
O3GMC's Avatar
12 Second Club
Originally Posted by 2toneblown
I have a question...Why would you even want to relocate it to the lower valance? When its in the grill it gets plenty of air flow if not more???????
I didn't like the idea of my heat exchanger, trans cooler, a/c condenser and radiator all being stacked in front of each other. It might also be harder to upgrade to a larger trans cooler. Besides, the opening in my valence is the perfect size. The only downside would be if you hit a tire or some large object on the highway....although it would have to destroy the valence and everything to damage the h/e. My h/e gets a few more rock dings and stuff than if it was behind the grille....but I think it gets better airflow and its one less thing for the air to hit before the radiator.
Old 02-06-2005 | 07:11 PM
Unfortunatly, I did not get a chance to monitor the before and after. I suspect the IAT is about the same, at least intially. What noticably better is the recovery time between full throttle runs. Cooling down the water used to take 10-15 min, only takes 2-3 minutes.
Old 02-06-2005 | 07:21 PM
moregrip's Avatar
what a rush!
Very Nice!
cheyenne383
11-13-2015 09:24 AM
03sierraslt
11
10-27-2015 03:38 PM
turbo6c3
10-05-2015 06:11 PM
old motorhead
09-29-2015 08:22 PM
bagged7104SS
09-24-2015 08:42 PM
Quick Reply: Radix heat exchanger
