Radix idle issue update
Old 01-03-2005 | 01:10 AM
  #41
Flyer's Avatar
Good point ... and the sharp edges on that aluminum loves to eat o-rings.
Geez .. the magna rep should be shot for letting them leave all those sharp edges on it. I have scars from them.
Old 01-03-2005 | 01:11 AM
  #42
BlownChevy's Avatar
blownerator
Just use more LUBE!
Old 01-03-2005 | 01:25 AM
  #43
Ryan23silverado's Avatar
Ya I have thought about Tex's opening of the intercooler, but that thing isn't too hard to seal up.
Either he is out tuning or he just went to bed Bueller...Bueller
Old 01-03-2005 | 07:44 AM
  #44
BigTex's Avatar
It was bed time boys, 2 hours earlier for me.
Here is my base spark table. I'll make the suggested changes, but I didn't think I was flowing that much at idle.
I'll check the injector o-rings, they weren't lubes well. But thats a vac leak which should make a higher idle.
Old 01-03-2005 | 09:12 AM
  #45
BigTex's Avatar
Originally Posted by Crash Dummy
It looks like your timing is falling off before it dies go to your Base spark in drive table and put 20 deg in it all tha way down to 0.60 and 15 below that. You can see on your scan the timing going from 19 on your high oct table to like 5 on your base spark table also turn off your idle proportional fuel table that will help alot.
Lets not forget that I'm traveling 18 mph here. This is a normal decel coming to a stop sign. I hadn't applied the brake yet. Spark was fine at the time. Should it use base spark table at 18 mph? Lets look at the same thing almost 1 second later:
Timing is at 16*.
MAF is still 1.4x
Throttle position is up to 11%
RPMS are still falling hard - now at 242 rpms.
* at the point timing falls to 8*, rpms are 123 and its just about to die.
It also looks like it goes rich before it dies and the fuel trims jump to neg-5 but with a cam I think I would try the above first .
Somewhat ignore these trim values. I had just fixed the fuel regulator and also replaced a leaking header collector gasket. Trim values were off from those issues, and were quickly correcting themselves. You are seeing the first time the PCM hit trim cell 4 and 8 since the fixes, so trims were working themselves back in line at the time. O2 sensors are reading .800s, so we can assume its getting fuel.
Old 01-03-2005 | 09:51 AM
  #46
Flyer's Avatar
It's going to use base spark when there is no throttle applied I believe.
Old 01-03-2005 | 09:53 AM
  #47
Flyer's Avatar
I would change the 1200 column to 20* also. It's going to trasition up to 27 from 20 between 800 and 1200 rpms, which will make for a real abrupt change.
Old 01-03-2005 | 11:07 AM
  #48
BigTex's Avatar
I noticed the 20-27 change too. Thats on my list of items to correct.
If thats the case, then when rpms drop, its going to pull from further down the grams/cyl column and bring in lower spark. I'll make that change to 20* all the way down, but I don't think its the cause of my issue.
Good info guys.
Old 01-03-2005 | 01:48 PM
  #49
throttle cracker.
yes it uses base spark when 0% tps is commanded.
Old 01-04-2005 | 08:59 PM
  #50
BlownChevy's Avatar
blownerator
Update?
Quick Reply: Radix idle issue update
