Radix and Nitrous?
Re: Radix and Nitrous?
i was joking.. i wouldnt do that.
anywho..
i want a supercharger as well, and being 17 years of age,, its hard to get 5k dollars.. being that i pay my own truck payment and stuff.
But at least I can say its my truck.. later on when im like 21 I might have enough money, and by that time maybe a turbo kit will be out.
anywho..
If you look around in the forced induction or NO2 forums, you will find a vette that had a Radix type blower, MagnaCharger that wasn't side mounted but not intercooled either, and had a nitrous backfire. It was NOT a pretty site.
single digit dreamer
Some of yall are going dual power adders. I was just wondering if it is possible to mix the radix with nitrous being that you are not suppose to run nitrous through the blower. Would a direct port system be possible or is that too much?
BTW, if you think a 4L60E can hold that...look elsewhere for a trans. A 4L80E swap would be ideal.
You need a TON of fuel to run 8-10psi and a 150hp direct port. I'd run a large dry shot through the blower or a 100hp or less wet through the blower. Just be careful and go in moderation when using dual power adders. Dry also becomes pretty inconstant (from experience) with large shots. I used to spray a 175hp shot and it was iffy at those levels...a 125-150hp was just easier to mess with and seemed to be better.
As far as running nitrous through the blower, I was always told that was a big No No! I thought that was why that corvette with the magna charger had problem.
Can anyone confirm this, that running NITROUS through the blower it BAD?
And the tranny, well I know for a fact that it can barely handle the stock 5.3, and am planning on getting mine built up before any major modification.
couple of problems here, with alot of boost you may max out the maf with just the blower, add a dry shot to that and it will be maxed for sure so a dry shot is out of the question unless you figure out a way to get that maf to read higher(there is a way but more money)
spraying a wet thru the blower is a no no but it is convienent and easy so people do it, the best bet would be a DP but looks to me like there isn't alot of room under that blower to plumb a DP. can someone toss up some good pic's of that radix, any pics of where a DP could be plumbed, i dont think it can be done but some pic's might help.
oh yea, i think the stock lines would handle it but you will probably have to stage the pumps.
a single inline probably wont handle it and a biger pump will out flow the return line at idle. someone around here tried a areomotive 500lb/hr @45psi pump and couldn't control the fuel presure. the single inline shows 360lb/hr at that presure and the return line could handle that. you will have to figure out a way to stage the fuel pumps so you dont get all the flow at idle if you want to use the stock lines.
Adkoonerstrator
http://www.magnacharger.com/pdf/manual01.pdf
Scroll down to page 26 and it shows a decent picture of the fuel rail setup. You could probably fit a NOS Nozzle DP or whatever they call it under there.
hell no gas prob on the direct port. use propane as your gas source. that would solve the gas prob. If i understand the whole concept correctly i have read that they were running nitrous through the nitrous line and propane through the gas line of the dp system. any body else know about this? said the propane is like 100 something octane and burns slower and better/cleaner or something.
what do you folks know about this?
Ryan
Ryan
