Radix and Nitrous?
#21
Re: Radix and Nitrous?
the best bet would be a DP but looks to me like there isn't alot of room under that blower to plumb a DP
You make a good point about the maf. I have no clue how to solve that problem.
There is a method to my madness. I want to make the ultimate sleeper. The radix is a relatively quiet charger compared to the procharger, and it is very streetable. I thought adding a little nitrous to it would help it even more. It is just another one of my crazy ideas, but I think with more research it could work. I mainly want to establish a set plan before I start to buy things.
#22
SleekSilverado...Hell, save the hassle of trying to figure out a nitrous shot...a little 35hp wet shot through the blower would cool everything down a ton and still be sorta safe...and go with a bigger cam, better heads, billet rods, forged crank, and 9.0:1 pistons for a super strong bottom end. Use ARP studs all over and o-ring the head gaskets then turn up the boost to ~15psi and hold on. More consistant power.
SleeperSilverado...Propane burns slower and at a higher octane count. That is why it works kick *** in diesel applications. If you are trying to just do that why not get a fuel cel for some 110 unleaded for race purposes only. Why spray through the blower? Can't you just drill a small hole in the TB for the Nitrous nossle?
#23
i am not saying spray through the blower. i am saying go direct port with propane as your fuel. i see what you are saying and that is how alot of people handle the gas situation. but i figuse it would be easier and cheaper to use propane. think about it what else do you need that you dont have posibly a bottle and some lines. you already have the sylinoid. i was just saying use propane from a cost stand point. it seems you would not spend much there. were with a fuel cell and pump and the time to make it work would be a lot more expensive.
i have not looked into it that extensivly but looking from a distance it looks to be a hell of a lot cheeper.
#24
gavin2005
09-13-2015 09:04 PM
06murder
09-04-2015 03:54 PM
