Radix prefers open or closed air filter?
Old 06-18-2005 | 11:02 AM
1SlowHoe's Avatar
Destroyer of Transmissions
Default Radix prefers open or closed air filter?
I have a radix on my 5.3. I had a crappy open cone filter (ebay) and it worked fine. Recently went back to the stock air box/filter and I can feel a difference believe it or not. My question is would the Radix breathe better on an open style filter or should I get a K&N filter to drop in the stock air box or another system altogether? Thanks for the inputs.
Old 06-18-2005 | 12:43 PM
Crash Dummy's Avatar
Former Moderator :(
I would recomend the Airaid, I have it and its not noisy and it seal against the hood real good to keep that unwanted heat out.
Old 06-18-2005 | 12:50 PM
qwank's Avatar
try a k and N drop in and cut out the side of the air box that faces the fender so its similar to a duramax air box. i'm using this set up N/A with a volant MIT and it works great, bet it works better with a radix
Old 06-18-2005 | 12:54 PM
1SlowHoe's Avatar
Do you happen to have a pic of that set up?
Old 06-18-2005 | 12:58 PM
qwank's Avatar
no i dont sorry. i'll try to get one later on today
Old 06-18-2005 | 03:37 PM
wkdivr's Avatar
I drilled some 2" holes in the front of my airbox, and removed the deflector between the rad support and headlight bracket. At the track, I take out the right headlight. Works pretty good. I have the K&N panel that came in the Radix kit.
Old 06-18-2005 | 03:47 PM
moregrip's Avatar
what a rush!
I've seen the Airaid setup firsthand, impressive
Old 06-18-2005 | 03:52 PM
wkdivr's Avatar
Anybody give any more thought into the Outlaw set-up for a Radix application?
Old 06-18-2005 | 08:35 PM
thunder550's Avatar
High on diesel fumes
I was told that with a blower a CAI kit won't be any benefit? Was I told wrong?
1bdbrd
08-23-2015 03:24 PM
Jake99
08-08-2015 07:56 AM
Onetogofast
07-27-2015 08:33 AM
rojeho
07-12-2015 06:10 PM
Quick Reply: Radix prefers open or closed air filter?
