Radix Question, missing coolant??
Old 05-02-2004, 09:51 AM
blownerator
BlownChevy's Avatar
Originally Posted by -= MacADaYear =-
What did you replace with?
Still have the DexCool in my truck....I just change it often.
Radix is using Green Coolant.
Old 05-02-2004, 09:52 AM
blownerator
BlownChevy's Avatar
Originally Posted by vortec327
Will do, this is strange
I will me seeing Manga Charger today @ the Super Chevy Show, I will ask if they know of any issues.
Old 05-02-2004, 10:10 AM
carbon04's Avatar
just a question, but does the radix's coolant mix with the engines coolant?? and i have heard that it only gels up when mixed with the green coolant, is this true or does it gel by itself?
Old 05-02-2004, 11:50 AM
Flyer's Avatar
THe 2 systems are completely isolated. The RADIX coolant runs through it's own pump and it's own openings in the blower. There aren't any coolant passages in the intake manifold like in the old days if that's what you were thinking about.
Old 05-03-2004, 12:06 PM
I have Dex-cool in my Radix res. If Magna is recommending not using it, then they need to specify that in their instructions. Did I miss something? It's not a problem switching over, just wish I would have known beforehand. Thanks for the info, Brian.
Old 05-03-2004, 12:09 PM
blownerator
BlownChevy's Avatar
This is something that I discoverd via a friend in the service dept @ the dealer. I am pretty sure it is not going to damage your Radix, I just choose to use the green in the Radix, just like the lightning uses in theirs....works for them, then it works for me. I figure that if something comes of it over time it is better to replace a radiator than a intercooler in the Radix.
Infact I have used this in some of my vehicles with "cool" results:
http://www.neosyntheticoil.com/cooling.htm
Old 05-03-2004, 07:49 PM
slimsoftball's Avatar
Now you got me thinking of switching to green. What is the best way to flush out the intercooler in the radix? Since I will be installing the heat exchanger upggrade this week (finally) I could change the coolant then too.
Old 05-04-2004, 06:44 PM
I just changed mine to green,no big deal. The good thing is if i get a coolant
leak ill know right away were its comming from.
Old 05-23-2004, 06:25 PM
vortec327's Avatar
Intercooler bottle was cracked. Problem solved! Thanks for your help Brian!!
Old 05-23-2004, 07:04 PM
Glad you found the problem. Maybe one day they'll give us better made reserviors.
Quick Reply: Radix Question, missing coolant??
