Radix Track Times
#32
Originally Posted by j's01silverado
Magnacharger installed my kit and it is the radix intercooled. They said my flowmaster was too restrictive and caused my boost to go to like 9lbs so they had to install a larger pulley. Changing to magnaflow and then to a smaller pulley. I dont know what the elevation at sears point is. How do you launch your truck? Mine will just spin. I need some slicks.
#33
If you get traction problems solved you will have a 13 second slip I would bet. Borrow some sticky tires or something and then go get some better times.
As for a better tire, move down a size, like xxx/60/16 or something like that. That will make it wider. Are you still on factory tires, if so you probably were spinning all the way down the track.
#34
265 60 16
Stock size was a 255 60 16
ARC
57
02-21-2022 10:54 AM
therock
07-25-2015 09:23 AM
GMCtrk
07-17-2015 06:39 PM
