Radix Track Times
Old 05-18-2004, 06:38 AM
  #31
Formerly one92rs
one03sierra's Avatar
Talking
man i thought they would be quicker than that.i wanna see you get times when you get traction.
Old 05-18-2004, 08:17 AM
  #32
retsell's Avatar
Originally Posted by j's01silverado
Magnacharger installed my kit and it is the radix intercooled. They said my flowmaster was too restrictive and caused my boost to go to like 9lbs so they had to install a larger pulley. Changing to magnaflow and then to a smaller pulley. I dont know what the elevation at sears point is. How do you launch your truck? Mine will just spin. I need some slicks.
I have to ease into it really slowly. To stage I hold the brake and press the gass just enough to pull it up to about 1200 rpm, I let off the brake and feather into the gas slowly. I still spin, but it works better than just flooring it.
Old 05-18-2004, 11:55 AM
  #33
Flyer's Avatar
If you get traction problems solved you will have a 13 second slip I would bet. Borrow some sticky tires or something and then go get some better times.
As for a better tire, move down a size, like xxx/60/16 or something like that. That will make it wider. Are you still on factory tires, if so you probably were spinning all the way down the track.
Old 05-18-2004, 10:30 PM
  #34
retsell's Avatar
I have Firehawk Indie 500
265 60 16
Stock size was a 255 60 16
Old 05-19-2004, 02:07 AM
  #35
Flyer's Avatar
Sounds like they may as well be stock then ....
Get some tires and you will have a 13 second slip I bet.
ARC
57
02-21-2022 10:54 AM
therock
07-25-2015 09:23 AM
GMCtrk
07-17-2015 06:39 PM
GRRR65GTO
07-10-2015 08:27 PM
Quick Reply: Radix Track Times
