RADIX UPDATE
Tech Fanatic
Re: RADIX UPDATE
thanks for all of your suggestions! Im planning to maybe go to robbins bros. this sunday to maybe pick up the ring. gotta do financing though.
Re: RADIX UPDATE
Re: RADIX UPDATE
ok guys here is the full 24hour update
stock air box is too small for this hungry beast i have the "when to change air filter gauge" on the stock air box its maxed out indicating i have a dirty filter coool.
ill put my old FIPK kit back on and cut around the shroud to make it fit i think there is more power in there somewhere.
hey thanks for the welcome guys yes its well worth it
hey marineblue i seen some real nice rings for 99 dollars
Re: RADIX UPDATE
Don't use an open element filter,my Radix sucked a K&N cone filter completely flat.I use the K&N replacement panel with a UPD lid and a 4" homemade ramair pipe drawing cold air from below the bumper into the stock air box.You need to shorten the Magnacharger inlet tube to make it work.At the track I remove the filter.
