RADIX UPDATE
#22
Truck addict
Re: RADIX UPDATE
i have an engagement ring for sale. cheap. half karot(sp) i believe, sell cheap. looks great and helps you stay in the hunt for a charger. and helps me get a little closer to one as well. lol
#23
Re: RADIX UPDATE
i have lots of pics will upload them to somewhere and post a link.
installed a boost gauge today saw instant boost @ 6psi and above 4000rpm it will creep up to 7
has anyone installed a smaller pulley on the radix say 3" im trying to get it up to say 8 or 9 psi that would be the greatest is there an online place i could check out
#24
Re: RADIX UPDATE
Do you have the 3.4 pulley on it right now?? I have the 3.1" pulley from the 6.0 kit on the shelf. It would take the system to 9 lbs. Problem is, you can't get away with it on premium fuel. It seems that they start to detonate over 7 psi on pump gas. It would require race gas.
#25
Re: RADIX UPDATE
I see about 7 psi at first, and by 6000 it comes up to about 8.5. I had the 3.4 inch pulley on my 5.3. I never saw any KR or heard it either.
Mine was running pig rich though from the headers and maybe bad o2's.
#26
Re: RADIX UPDATE
yes i have the 3.4" pulley ...did more runs last night barely touched 7 psi @ 5500 RPM is that normal for the radix or should i be seeing more boost like Flyer
Ben thanks for the info looks like the 3.1 pulley is a bit too much..
i think ill leave the pulley alone truck is running so good rite now
#28
Re: RADIX UPDATE
#29
Re: RADIX UPDATE
The Lightnings 5.4L (8.4:1) engine has over 1 point less compression than a LM7 5.3L (9.5:1). This allows the Lightning to handle more boost easier. Not only that, the 5.4L engine in the Lightning has a rotating assembly designed for higher cylinder pressures as well.
