Ramjet on 96 L31
Ramjet on 96 L31
Hey i was wondering if i did the ramjet intake setup on my 96 L31 if i could use my wiring harness and PCM? i plan on spraying 100 shot, with new comp XFI cam and new springs. Also new gaskets and all that. all info appreciated!
Yes you can keep your oem computer and wiring harness. You will just need to run new wires for the injectors. Cut the oem injector/poppet plug off and rewire.
Here a pic of my marine intake. I decided to make my injector wiring detachable.
See this thread for more info about the marine intake and what needed to be done. It should help you with your ramjet swap.
http://www.pacificp.com/forum/viewtopic.php?t=317
Y2KLimited
08-03-2011 01:37 PM
