random missfire
Old 08-12-2008 | 10:26 PM
navy_ao_05's Avatar
Default random missfire
well my truck is throwing a random missfire on the 8th cylinder. i cant hear or feel it when its idling or driving around. i have changed to coil, spark plug, and the wire. i have no clue what else to do or look at...
thanks robert
Old 08-13-2008 | 11:27 AM
budhayes3's Avatar
PT's Slowest Truck
You could try swapping the injector with the one next to it and see if the misfire moves to that cylinder...
Old 08-13-2008 | 11:34 AM
Yeah man, sounds like a faulty injector to me too!
Old 08-13-2008 | 06:17 PM
navy_ao_05's Avatar
i will buy one tomorrow.
Old 08-13-2008 | 09:40 PM
budhayes3's Avatar
PT's Slowest Truck
Double check the electrical connection at the injector first, they've been known to come undone...
Old 08-13-2008 | 09:52 PM
86T-Top TA's Avatar
I work at a GMC dealership and we see alot of injectors plugged that are in the ends of the fuel rail on returnless fuel systems. if you remove the injector you should be able to see alot of gunk in the screen where the fuel comes into the injector
Old 08-17-2008 | 08:31 AM
navy_ao_05's Avatar
i went and bought a new fuel injector and the truck ran good for a day. now its doing it all again. when ever i floor it in first and it shifts into second it does not wanna go over 4000rpm but if you keep it floored or let out and floor it again sometimes it will go away. it almost sounds like it hitting the rev limiter.
Old 08-17-2008 | 09:20 AM
Truckshop's Avatar
have you checked fuel pressure? replaced fuel filter?
Old 08-17-2008 | 10:30 AM
navy_ao_05's Avatar
the motor only has 32000 miles on it. can i check the fuel pressure with hp tuners?
Old 08-17-2008 | 08:20 PM
budhayes3's Avatar
PT's Slowest Truck
You need a manual gauge connected to the fuel rail to check pressure
Quick Reply: random missfire
