Rapping Noise After Seafoam
I used seafoam a little while ago and just got back from deployent truck has not moved and still has bad rapping noise now, after using seafoam. No power loss at all runs perfect just sounds bad, any ideas before I just pull motor and drop in a replacement. No DTC at all either ! Please Help
when i first put seafoam in my truck and start it, it makes a rapping noise too and has a rough idle for maybe 5 seconds and goes back to normal. i run a whole can 50 miles before every oil change...as said change your oil and try to start it then, monitor oil pressure. does it do it under throttle? sound like a stuck lifter?
lukn4trbl355
10-22-2015 12:19 AM
