The real truck pull
Im sure you guys have all read about the half ton 5.3 tuging around a Hummer. Im not going to try to pump you guys full of **** I was just wondering if any body but me has hooked a weight transfer sled but me If so how did you do
![Chuck Ball](https://www.performancetrucks.net/forums/images/smilies2/chuck-ball.gif)
J/K
I would try it for ***** and giggles.
![Mr. Cool](https://www.performancetrucks.net/forums/images/smilies/LS1Tech/gr_cool.gif)
I have. couple of times 6500lbs street legal class. This was before cam and cat-back. 237' and took 7th place. top pull was 305'. But then again only mine was actually street legal and the only one driven to the event.
for the newb's out there - total combine weight of sled was around 44,000bls including weight in the box. Just when the front plate drops, you better have ground speed and the tires hooked. Or the sled with show you what your motor is made of.
Also found a club that seems to be willing to work with me on joining, since I am 5 ci over their cubic inch limit for street legal.
whippled HD: how you do, and what setup did you do?
Sorry the long reply, Just jazzed up about next season might be in the points race!!!
![Owned](https://www.performancetrucks.net/forums/images/smilies2/owned.gif)
Ive pulled several deferent distances depends on track. Ill tell you this my buddy has a 2001 dodge cummins 380 injectors Hollset HX40 ATS manifold JBD and EDGE comp box Enterprise Engine pulling clutch and 33-12.5 bfgs. Last pull i beat him by 15 feet. Im satisfied. At Shieds Deisel Estravaganza in August he laid down 496rwhp and 890rwft
![Driving](https://www.performancetrucks.net/forums/images/smilies/LS1Tech/gr_driving3.gif)
Ive pulled several deferent distances depends on track. Ill tell you this my buddy has a 2001 dodge cummins 380 injectors Hollset HX40 ATS manifold JBD and EDGE comp box Enterprise Engine pulling clutch and 33-12.5 bfgs. Last pull i beat him by 15 feet. Im satisfied. At Shieds Deisel Estravaganza in August he laid down 496rwhp and 890rwft ![Driving](https://www.performancetrucks.net/forums/images/smilies/LS1Tech/gr_driving3.gif)
