Really Confused About Cams
#21
Hows ur idle with the comp cam? And if I ran that cam and ls6 springs, stock head gasket thickness and recommendations on pushrod length? I'm not trying to half *** this but with it being my DD i dont really have time to pull it all apart and check the pushrod length then wait a week for the right ones to arrive ya know?
My idle has a mild chop to it. The cam is cut on a 114LSA
This is a video that I made for my brother after I got everything done to it, so ignore my commentary.
#23
A cam on a lower LSA tends to have more chop to it. It also moves the powerband to the left, which means more low end. Honestly, I'd get one spec'd for you by PatG. I think if you buy the cam from him, he gives you that $25 back in the price of the cam.
#24
Okay and PatG is a member on here? or what? I listened to your truck and a few more on youtube and from what i can tell the 212/218 comp cam has an idle i could deal with atleast until I get the money to do alot more to my tahoe to be able to run a bigger cam.
#27
Only if you can live with it dying on you in stop and go traffic and almost very time you engage the gear, ect... As it probably will.
Just don't hammer it too hard as you AFR will be totally out of whack until you tune it.
#28
This is my truck with the SDPC HT 1 cam. it is right on the verge of needing a stall i'm adding a fesh tans and a 2500 or so stall. You will need a tune or be really good and two footing.
VIDEO0031.3gp - YouTube
#29
The SDPC HT1 cam is what I recommended way back on page 1 of this thread. If he wants a lopey idle, that one will deliver.
Scoggin Dickey Parts Center CC54-ST1-11 - HT1 SDPC LSX Truck Cam 214/218 .559/.562 111 | SDParts - 1-800-456-0211
