Reduce engine power???
I was driving and lost power and the info center said reduce engine power. what does that mean ? The gas milage has not been right i think the fuel pump is going out but i dont know .
"Reduced Engine Power" can mean a couple things. If I remember correctly, the two main causes are either a bad throttle position sensor or the truck overheated.
Is the truck all stock? This msg can be all sorts of things. If the TB is stuck or sticking, bad ground, bent contact on the pigtail, broken wire...have u played with the TB or Tb wiring lately? U can clear it by disconnecting the battery for a few minutes then touching the 2 battery wires together - sort of a 'reboot' - but its not something I'd do often. If the problem is intermittent the msg will disappear and TB will operate normally until next occurrance. If it wont go away, I'd start with the TB & cables and work back from there. R/
I have a cold air thats it . i just put HIDS in. could it be that? it didnt start messing up until i put the hids in a few days ago. its going for warranty work to find the problem out. should i put the stock air box back on?
