Reduced engine power
#33
Originally Posted by GMC_DUDE
Linda,
As an electrical engineer who works with engine controllers for a living (albeit diesel instead of gas) I can tell you with 100% confidence that the smaller pulley had NOTHING to do with the pcm getting fried. It was merely a coincidence that the two happened together. Most likely there was either a manufacturing defect (I've seen it happen) or Westers touched one of the pins without grounding himself first, which caused a static spark and ESD damage, which typically shows up about 3-6 months later. Continue to enjoy your new pulley, get a tune, and make Westers give you a new pcm.
Had I caught this earlier I would have suggested the PCM because I know that the recent addition of a blower or smaller pulley always results in a new tune. Most people will recieve a new (Used) PCM through mail order from a tuner. Most guys recycle PCM's so that would have been the most logical place to start. When changing out a PCM it is imperative that the battery be disconnected or the electronics in the PCM are subjected to stray voltage/cross voltage/insufficient grounds for a brief period.
With all this said, I am glad you got it figured out Linda. I too have had issues with my PCM, mostly due to low battery voltage while I am reflashing.
Good Luck.....
ARC
57
02-21-2022 10:54 AM
bsgiffor
07-19-2015 11:14 AM
