reduced engine power...HELP!!!
Started the truck today (with my remote start) truck was running like ****. noticed reduced power and codes p2135 and p0220. Throttle position sensor voltage crap. I am running the 90mm throttle body with the x-link. Anyone have this problem? Could the x-link have an issue? I looked for any broken wires but found nothing obvious.
I think a member on this site had a similar issue a couple months ago. If I remember correctly, the problem turned out to be the gas pedal position sensor. I'd check to make sure this sensor is OK. I think it's under the gas pedal but I'm not sure.
if i keep the x-link on it only pulls two codes p2135 and p0220 but it will not allow me to clear codes. if i just put a adapter plug on I will pull those two codes plus p0120 p1516 and p2101 but it will allow me to clear codes. when the truck is in limp mode does it idle really rough?
Don't you just love Drive-by-Wire? Next comes Steer-by-Wire and Brake-by-Wire. The auto techs will be in school forever with all this new by-Wire crap. I'd like to see the Flat Rate manual on some of this new by-Wire stuff.
