Reg. Gas Fuel injector question
I have a 2006 Tahoe 5.3 with flex fuel manifold I want to convert to Reg Gas. I had a set of gas injectors that are about a 1/4" shorter the the Flex Fuel injectors.
The fuel rail is stainless steel.
Are there longer Gas injectors that i should obtain...or do I need a different fuel rail?
From test results I've read and articals I've read...even after tuning the PCM (to recognize FF injectors)...I will not get as good gas mileage out of flex fuel injectors. In addition my custom engine harness connectors for gas injectors, The flex fuel harness pugs are a different size.
Not true????
I really would like to run the right stuff...even if I have to change the fuel rails
Not true????
I forgot to say this accually an engine swap...so I do not have the e-85 sensor in the fuel line.
I wonder if that makes any difference in tuning?
I already had the PCM tuned for gas.
If I understsand correctly no other tuning of the PCM is required for using Flex Fuel injectors.
Now all I need to do is change the harness plugs to match the E-85 injectors...right?
Thanks to all of you for clearing this up for me..
If you had your computer tuned for regular gas injectors then yes you will have to be retuned for the flex fuel injectors. Do yourself a favor and keep the flex fuelers as they are 35lb injectors as opposed to the stock 24lber's. You would never run out of injector when you go to mod this motor unless you went forced induction.
