Removed my cats
Old 01-21-2004 | 12:00 PM
2ksleeper's Avatar
Originally Posted by davidmtz
I had gibson shorties on my 00 5.3 ext cab with many mods, so i removed the shorties and installed some as&m. Since I was already cutting the pipes I decided to remove the CATS and install an X-Pipe.
The truck feels very different, it feels like it has no power on the low end. I used to scratch second pretty hard and now it barely does. If i remove my K&N filter it feels very strong again but I can't help it wonder if the cats helped or if they made it worst????
What do you all think??
My opinion on removing cats is unless you have some sort of major power adder (ie supercharged, n2o, etc.) just leave them alone. When removing your cats you gain upper end horsepower but as a trade-off lose low end torque. Even with a supercharger when I removed the cats on my truck I noticed a lose in low end torque. Before removing the cats I had to run colder plugs gapped at .035" to keep from having the occasional spark knock problem. Now after removing the cats the exhaust flows better so I changed back to the stock heat range plug gapped .060" & it picked up a little low end power. As of yet it hasn't had any spark knock problems and the truck runs strong .
Old 01-21-2004 | 12:26 PM
Flyer's Avatar
It sounds like there is to little back pressure. Try the next size down X-pipe if your concerned about it. That should bottle neck it up a little for ya. If you can't find one a little smaller, get a cheap one. They don't flow as well as the better ones on the market.
madmann26
04-29-2020 09:17 AM
FlowmasterMufflers
11-24-2015 01:00 PM
cheyenne383
11-13-2015 09:24 AM
Angry Silverado
10-21-2015 07:07 PM
03sierraslt
14
10-09-2015 05:53 AM
Quick Reply: Removed my cats
