removing 4.8 and installing 6.0
#24
4.0 to 6.0 swap
Originally Posted by Dark Halo
I see alot of people go with the 4l80E over the 4l60E when swaping to a 6.0, is this a must? or will it just work out better?
#26
4.8 to 6.0 swap
Originally Posted by Yukonuba
I'm curious about the LSX intake...is that a truck specific intake or do you plan to do the mods required to make the lower "f-body" manifold fit? You will need to change mounting brackets & thermostat housings, and maybe a couple other items(?) to make it work on the truck if it isn't truck specific. Some guys on the forum have fiddled with it...some info here, but do a search to find more.
link
link
#27
Originally Posted by 6.0 modified
If you are going to be puting in a 6.0, I would suggest to use the 4L80E trans, you can use the 4L60 but in time it will fail, I am installing a 6.0 (modified) 408 c.i. and going with a 4L80E with a transgo shift kit and changing out the clutches
#28
Tribe Shaman
what i found out
wiring will work 99 - 03 4.8 5.3 6.0 all the same
pcm will work 99 - 03 4.8 5.3 6.0 all will run off each others, upgrade to motor installed cheap at dealer.
6.0 fly wheel holes will not line up to the 4l60e converter. need 4l80e trans
your courrent drive shaft will not work with a 4l80e it is too long.
diffrence between 4.8 and 5.3 pistons, crank and rods
6.0 has diffrent heads, pistons, crank and rods
everything else on motors 4.8 5.3 6.0 99 - 03 all the same
was working on my project until i found out money and time was wasted.
still looking for a 6.0 4l80e trans and drive shaft, swaped my 6.0 heads for powerdyne charger, swaped my 5.3 crank and rods and berrings for 75 nos shot, one of these days i will smoke that rice burnen weed eatter
